After accomplishing my KX fork swap...which I love....I've started to notice a little play in the new bearings I put into the steering headset. Everything is still torqued to spec..even tried slightly "over torquing" to try to draw the headset together...zero effect...still some minor movement.
Question for all...how much if any play do you have in your stock steering stem/headset bearings? Mine is very little but by the time it's magnified at the front hub there's as much as a .25 inch in "wiggle" where the tire makes it's contact patch.
The way I check this is..bike on a maint. stand..front wheel off the ground....stand if front of the forks and gently pull/push on the fork tubes. This makes the movement I refer to.
Just for grins tried out a buds YZ 250 to see if it had any "head play"...it was rock solid..undetectable. Not an "apples to apples" comparison but left me curious. I honestly can't remember ever noticing this on the stock setup.
Can't say this has affected the handling any....we've run the bike up to 6th pinned on some desert trails...it's shmooov...with the exception of the "wiggle" which does get felt in the bars (as a slight "thunk") on the occasional bump
Thanks in advance for the comments fellas,
Eric
Eric
