rxraptor02
- Aug 7, 2004
- 34
- 0
guys,
I have been searching and I think I have found some of my answers but I would like some input on this.
I want to turn the tail light into a brake and tail light.
this is the process of what I plan to do....
From what I read I need to get a resistor and install it on the gpositive wire leading to the tail light? that will dim the tail light.
then from the hydrolic pressure switch install that before the resistor and after it. so when the switch is pressed it will bypass the resistor allowing full watts to the light.
Does this sound correct?
if this is correct what kind of resistor will I need to buy? watts/ohm I am not sure...
I also plan on doing this to the headlight but I didnt find any info on that, but my guess it would be the same. but would the size of the resistor need to be bigger since the headlight has more watts?
thanks
-Jim
thanks
-Jim
