Ok here's what happened, my son on his 07 kx85 dumped his bike In a corner gearshift side and now it's stuck in 3rd, you can move the shifter all the way up and down, there is tension on the shifter but it won't engage into a gear, new shifter so it's not stripped, but upon closer look it looks as though the shifter shaft has pulled out about a half an inch, the shifter is farther away from the case and it's not bent, any ideas?
