Suzuki Clutch Rebuild RM125 Push Rod
I already did all this stuff to the clutch components and I'm almost done putting it back together. I just need to put the outer pressure plate on and slide the push rod in. The problem is that the push rod just goes way in there - too far I think. Is there something on the other end or side that I need to mess with? How do you put the rod in?
Nevermind. The answer is pretty obvious. The rod and pusher go in before the pressure plate goes on. I wasn't really thinking about how it works before.
