Swapping back and forth in whoops
MXTex
417
When I'm really pushing it through the whoops the rear of my bike starts to swap back and forth. The bike is a 98 KX250. Suspension by MXTech. I realize this is probably rider error but any suggestions on where to go with my clicker settings would be appreciated.
MXTex
weatie181
9
Here are a couple of things to try..You should check the race sag, then speed up the rebound a couple of clicks. ( if it is to slow, the shock will not use full travel, and it will have packing.) If it gets worse, go a little slower. If that doesn't help, then use the comp. adj. Start by going a click or two softer, and if it gets worse, go a click or two stiffer from the original setting..
