To rich?
97 kx250, i get all kinds of black stuff coming out of the pipe where it meets the silencer. Its about 15 degrees, i have a 170 jety in it now.
i have good commprerssion, 65psi first kick and about 170 psi final, if you have good commpression, is it still possible to have blowby
I KNOW SOMEBODY HAS SOME FEEDBACK, YOU GUYS ARE VERY HELPFUL, I REALLY NEEDS FEEDBACK THANKS
MrLuckey
Fire Marshall Ed
Did it just start spooging all of a sudden? If so, did it seem to coincide with temperature drop? Could it be that your packing is now saturated and just letting more by? What pilot, needle and clip position? Pump gas? Oil brand and ratio?
More details will probably make it easier for someone to give you better ideas on what is going on.
Have a bit of patience, it's Monday and a lot of folks are probably busy getting caught up with work stuff, recovering from the weekend etc. I'm sure some of our jetting experts will try to help you out before too long, in the mean time provide as many details as possible.
are you fouling plugs? is it still running factory jetting? did it ever spooge before? how long since last rebuild? what heat range of plug? thats a good start to some questions ?
