Do you trim your bars?
  • Yes
    Votes: 22 38.6%
  • No
    Votes: 35 61.4%
  • Total voters
    57
Papakeith
COTT Champ Emeritus
6,695
50
RI
nope, just wheelie through the tight trees and turn the bars to fit.
Or, in my case, stop, wedge one side through, push forward an inch, swear at the &&**%$ tree, lean the bike to the side, push the other side of the bar through simultaneously ripping flesh from your knuckle, swear at the *&&$$%%## tree again and at the guy who laid the course out, push bike forward another inch, get foot caught between tree and swingarm, back up an inch, release foot, push forward a bit more, stall the bike, dismount(forgetting that the ground drops away on the side you decide to get off on) and fall flat on your kiester while your buddy(who has tears running down his face from laughing so hard) points out the line that runs to the outside of the two tight trees.
what about oxygen.
i dont really see the point in trimming the bars. most trails that i ride on are made for bikes so their arent gonna be trees that really get in the way.
except for that one that you think you can make it then you clip the edge of the bar. then you get to freak out on the tree that came out of nowhere :D
nikki
Moto Junkie
Apr 21, 2000
5,802
Yep.... I run Pro Taper SE's and cut somwhere between the second and third notch on each side. I think each notch might be a 1/4", so I'm taking off a little over 1" total. Main reason I cut them is because I'm a shorty (5'5"), so it's more comfortable for me, plus I think it makes for better cornering for me. If I remember right (too lazy to look up the charts online), all bends of Pro Tapers all come in the same standard width, unlike Renthals and Tags that come in different widths for different bend styles.
BadgerMan
2,479
10
XRpredator said:
I trim.
oh, we're talkin' handlebars . . . never mind
Handlebars........not Speedos........ :yikes:
WoodsRider
2,812
For the rocky stuff, where I normally ride, my bars are stock width, 32.5" barkbuster to barkbuster, for more control. When I race in Jersey I have a pair of cut-down mini bars, 29.5" barkbuster to barkbuster, for the miles of endless ignorant-tight stuff.
adam728
1,011
Mine are trimmed to just under 31". I just feel more comfortable with slightly narrower hand spacing. I may go a touch more, we'll see.
patto3
153
I trimmed mine once and it felt alright except it did give me a bit more headshake. I don't think I will be trimming the bars on my new bike.
MeanorMX
91
I have monkey limbs so I tend not to trim things because of my longer arms. My friend has a CR 125 that has the bars trimmed and I'm just too cramped.
YamaB
401
I race primarily harescrambles, so I use trimmed bars... They really help in a lot of the tight trails that we race on...
Steve St.Laurent
255
I trim mine down to 30" wide at the bark busters so the bars are about 29". Much wider than that and I'd be smacking WAY too many trees. I love the real tight technical stuff!
Pushin50
136
I have short arms so I need to cut 1/2" off each side so they fit me. I am also lazy so I just move the grips in 1/2" on each side and call it good.
wake_rider
481
When you're 6'3" you need your bars as wide as possible. I just use Bark busters to keep the hands healthy.
