95xr250
95
top end is piston, rings, and connectin rod and rod bearings. bottom end refers to the crank shaft and all of the gears and clutch.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Errr.. wrong
Top end does not include the rod... It only includes the piston, rings and wristpin & bearing.
The rod, Crank and rod bearing are part of the bottom end.
Clutch is not part of a bottom end rebuild.. That would be a clutch rebuild.
Moose
1,091
84cr125 said:
This used to be a good site, untill people with no experience come here and start posting things that arnt true.
You've been here since April 8th, are you sure you've seen enough posts to be certain of that? :coocoo:
Indy's explanation was exactly what I was thinking too.
