123654
47
Thanks for the info.
I guess I need a new top end because it takes a lot more kicks after the last time I road it.
Would long periods of top speed do that to a 125 motor?
Darren
123654
47
Thanks,
The last hare scramble I did had about 5 places were you would be at top speed for 1-2 minutes. That must I did it.
Darren
jboomer
1,420
When was the last time you did a top end? If it was fresh before the hare scramble, that little bit wouldn't wear it completely out! I just meant 125's will wear out topend's more FREQUENTLY than a larger displacement bike. It really depends on how you ride. Hard, high RPM riding will require frequent ring changes (matter of hours), casual-moderate riding will require less frequent (couple of months).
pyrofreak
819
My YZ80 is harder to kick over than it was when i got it. It doesnt seem like it has any compression. I have been fouling plugs and i was wondering if the quote you posted goes for the 80ccs too?
handleme46
59
The smaller the displacement, the more rev's needed to make competitive power, so yes pyrofreak your 80cc top end is probably just needing a top end rebuild.
123654
47
The top end was not new. I put a new one in at the begining of the summer. I keep my 125 at high rpm's when I ride it.
