Being located in South Africa, and having a pretty shoddy currency value and postal system, I have decided to try and make my own torque ring for my '01 220. :nod:
From what I can see it is a flat alloy spacer, with and identical diameter and sidewall thickness as the end of the pipe, and it looks to be 3-4mm thick. Is this correct so far? Is the spacer simply inserted between the pipe and the head as to change the effective length of the header?
I guess the thickness is pretty critical to how effective it will be. Has anyone played with different thicknesses to see the effect of it?
