Feb 25, 2001
394
Im looking into hooking up my trailer 7X16 enclosed trailer with A/C does anyone know a company that sells the units ? I guess I just cut open a hole in the roof where the vent is currently. Its a tandem axle Horten Hauler trailer.
mx547
Ortho doc's wet dream
4,787
102
if you do away with your vent, i might be interested in buying it. my trailer doesn't have one.
nikki
Moto Junkie
Apr 21, 2000
5,802
We got a used roof air (from a RV) for our trailer - it should fit right in where the vent currently is. Motogrl is right - check out camping/RV/trailer places. I want to say the new roof air units run around $450-650.
mx547
4,787
102
Originally posted by justql
How was your trailer Saturday night?
it was pretty hot. i had two fans running off a marine battery and inverter. at about 2:00 a.m. i got the first low battery warning. i shut off everything except the fan that was on me (selfish). the warning went off again about 4:00 a.m. i shut it down for awhile, then turned it on again. it only lasted about fifteen minutes. by then it was almost cool enough to sleep.
i had my generator with me but i was too lazy/sleepy to get it out and fire it up. i figured it would just keep me awake anyway. i ended up getting about five hours of sleep.
and how was your air-conditioned camper? wimp...;)
mx547
4,787
102
how much generator power do you need to run it? or do you just use it when you have electrical hook-ups?
High Desert XR400
151
A/C
I could be wrong, but I believe that unless you are hooked to a 120 volt power supply you will need to run the generator to be able to run the AC. Some places discouage the use of generators after 10:00 PM.
nikki
Moto Junkie
Apr 21, 2000
5,802
We use a 5000 watt generator to run the A/C along with the other goodies (fans, tv, vcr, lights, etc...) we have the trailer wired through 2 circuits (the big 240? volt plug from the generator hooks to the trailer) One circuit is just the A/C unit and the other is everything else.
I want to say that you need at least 3000-3500 watts to run the roof air. If we plug in to a 120? volt electircal hook up - it only runs the one circuit (no A/C).
mx547
4,787
102
looks like i won't be getting air anytime soon. my generator is only 1850 watts. man, all this stuff is getting expensive!
KLX4smoke
159
If power usage and $$$ are the main factors, you could get a regular home window ac unit that can be mounted in the wall. You may need to fabricate some bracing for the unit, and obviously cut a hole in your trailer wall. Sharp makes a unit that is very quiet for about $200 and it only uses 500 watts. (5000 btu?) That is their model # fr50bx if I remember right. But there are many different brands and models that are under 1000 watts power usage for even cheaper. This setup works for me in my camper van, and runs on my wimpy(quiet) Yamaha 800watt generator all night long.
Motogrl307
93
An RV A/C only takes 1300 watts to run. We have a 2500 watt honda and it runs our air and lights fine. You can't run the A/C with the microwave at the same time but everything else is fine
KLX4smoke
159
OK, I looked at my Sharp model AF-R50BX and the tag shows this...
5000btu
4.5 Amps
500 Watt
It runs on normal house current (110 volt) and my Yamaha generator runs it and my tv/vcr and some lights and the water pump just fine.
Tony Williams
592
I see Honda has upgraded their briefcase size generator from 1000 to 2000 watts. About $850
With that, you could run a microwave also.
mx547
4,787
102
i don't know how the honda compares in features but i got my coleman 1850 new (freight damaged) off ebay for $280.
