Status
Not open for further replies.
aluttrell
Hi. What are my options for changing my transmission fluid? Can I use 30w oil or do I have to get branded transmission fluid?
Race_Bennett
51
whatever your manual sais for oil type. It dosent make an extreme difference . I usualy buy normal oil and change about half way through the year depending on the riding amount. Just check and see with the pull out bolt to see if its milky looking every time you ride.
rpm12505
190
We use ATF type F and change it every ride with no problems. Tried designer oils... No difference just more money. ( MX 125 style of riding )
DLHamblin
268
If you do a search under transmission fluid you will find this topic has been debated here many times and you will see al the pro's and con's on regular motor oil, ATF, and specific tranny oil (there is a lot of topics on this).
That will allow you to decide on your choice. Any will work, some better than the others.
Status
