bearcub1985
i have a 72 pdv 125cc, it is in rough shape but the engine runs good
my problem is that it shifts fine down from 1-2-3-4 and up but from first back into neutral it wont shift, so i usually just stall it out and then after a few tries i can get it back into neutral.
also i have another two newbie questions
- for the oil injections i have been just using regular 2-stroke oil (like you mix to put in the lawn mower) is that what i should be using?
- also what type of transmission fluid should i use?
thanks in advance for any help
Moto Man26
41
For your shifting into neutral,only a little pull upwards on the shifter should work or else it will go back into 2nd.
You should NEVER use normal lawnmower or weed eater/chainsaw 2 stroke oil for your dirtbike. Those oils are too cheap and can ruin your engine. You should use Yamalube or other good 2 stroke oils usually found at your local parts dealer.
And for your transmission oil, use Bel-Ray Gear saver, it works great, or other good transmission oils.
