Try this.
Hold down the stop button while the test is running. You can let off faster than you can hit it. I can get .11's by doing this, but my non cheating score ran about .27. It's addictive, don't you think?
kmx125r
Subscriber
I can't stop...
Sage,
Thanks for the link... Now I know what to do when its a bit slow at work!
I had two at .16 and two at .17, but mostly I get .22...
Later...
Man, that is addicting! My fastest time was .11 without doing the little trick Danny mentioned. I got a .05 using the trick.
Need Tips
Help. I tried the test and am trying to find a heavier spring for my mouse as the stock spring is too wimpy and doesn't rebound fast enough. Can I change the compression settings and what lubrication works with a MS mouse? Can I use silicon or should I try Maxima 927. Finger pump sucks!:cool:
canyncarvr
Subscriber
I hit the mouse button hard enough to move the pointer...then it doesn't register at all...by the time I move the pointer back and press it again... it asks me if I fell asleep!!..........:(
fatty_k
Subscriber
I was getting .11's but I got my mom to try and she got .06 without using the trick!!
