I trying to remove the cir-clips holding in the pivot type bearing on the relay arm of the suspension linkage. All the other bearings were typical roller type that pressed out fine. This pesky bearing has two cir-clips, one on each side holding it in place. Ive tryed everthing from an awl to a big fish hook to pry up an end,but the darn thing just spins in the groove. The bearing actually, suprisingly, seems fine, but not to replace it seems half azz, But Im starting to gauge the aluminum some :bang: Please help. Thanks.
