canyncarvr
4,005
Finally gave up on fixing my OEM shell..got a twinlight UFO.
Was surprised to find the straps seem to be for inverted forks..they're too big for my kdx.
The dealer is nonplussed. Doesn't have any straps that are different than what I have.
There has to be an answer better than 'Hmmmm...'.
Any have one??
Don't know why it would be hard to make a strap that would fit BOTH types of forks..but that's not the case.
Thanks!
Well...THAT took a couple of minutes!!
Thanks dan!!
acutemp
197
CC, I will send the straps that came with my WER install kit, There is only 2 of them as they only replace the bottom mount.--Dan
DENNY
218
I have the standard UFO head light on my 2001 KDX and if you take the rubber grommets out of the OME. Then put them in the 2 upper strap holes on your UFO. It will bolt up to the upper mounting bracket. Then use the straps to hold the bottom.
