mcgyver6857
- Jul 20, 2001
- 45
- 0
I ended up buying a 1990 thats in awesome condition. 1991 was a pos. I changed the crank case oil used 10w30 thats what the manual said. I used mobil oil will that be ok or should I use the kawi stuff? Also I used a premix of 32:1 8oz/2gal, I hope thats right. I used yama lube seeing I had a gallon left over from a four wheeler. I was wondering since I'm going to do mainly trail riding if it would ok to run a generic oil, like stuff I can get a local store, ie walmart crap. If I can't run that what do some of you run? I need it to be resonably priced because I plan on doing a lot of riding.
Another note after changing the fluids and giving the bike a decent going through I took it out for the madien voyage. Everything was going great for about the first 4 hours. About this time the bike decided it was going to be a B ! T C H. Stuck throtle. Scared the poop outta me. Locked up the front brakes and took her down. Got up looked it over, looked fine, the cable wasn't pinched, throtle preceed to snap back just like before, everything was normal. Started it back up everything was good, rode it home and around my feild, no problems. So could this be a fluke thing? What should i do, replace the cable just to be safe?
