Ok all, I'm worming on an ATK 260, rotax engine, 160watt lighting coil in it. I need to wire in a regulator to it. A/C voltage. The lights are wired without ground.
Head ==============stator=========tail
Ok I've tried t he Moose regulator in series and blowed a bulb instantly. So we know that is wrong. I wired it parallel lights worked for one ride thought YEA its fixed. Next ride blowed bulbs to the point the glass broke. :bang:
Now the question. Yellow and Brown wires on the VR. Should it be hooked to only one wire and the other shunted to ground, or do you think I just had a wire come loose on the regulator....
I haven't really checked it completely yet with a multi testor, I did look and the wires appear to be still connected.
Terry
Terry
