carts69
24
Just replaced water pump seal/oil seal/bearing etc, filled radiator with coolant & without even starting the bike the coolant is dripping from the weep hole below the pump case, can anyone shed some light on whats gone wrong?
carts69
24
Yes that may be the case as ive not changed that? can you tell me if there shoud be a gap when you look down the weep hole, i have now removed the side case & when i look down through the weep hole there is a gap as if two pieces are not butting up to form a seal (or should it be like that)? im happy ive driven the water seal all the way in & fairly sure the bearing on the inside is fully home but should there be a gap when looking down the weep hole?
