Wondering why there is a clicking noise in or around the fuse box, any thoughts on why and how could i fix it. Sometimes the bike doesnt start with the electric start and have to use the kick start.
Does the noise happen only when you try to start it (with the starter engaged) or when it's running (or both)? Does the clicking increase with engine speed? If yes, check for a loose cam chain. If it only happens while trying to start it, check the starter solenoid. Is the battery fully charged?
I don't know how the fuse box could cause the sound, so I'd guess that the noise is coming from something else.
A video of this noise would be helpful.
BTW: If you don't have an owner's manual for your bike, here's a copy.
It only happens if u start it.
Thx will charge the battery to full and see if that helps. And before i pulled the whole bike apart it and restored it, it would start up perfectly fine.
