rm 125 hood
- Jun 29, 2010
- 16
- 0
what engine oil is it that goes into the engine/crankcase
if thats been giving you good results stick with it. but in my experience it is ok to switch as i have done so with no ill results. i switched a few times in the past til i found what worked best, i was looking to get rid of notchy shifts at the time. ended up with ATF type F. would have liked to stick with the mobil 10w just because you can get it anywhere and atf type f most times can only be found at auto parts stores in my area1998RM250 said:I've been using Mobil1 10-40w non synthetic, would it be okay to switch to atf? My clutch has about 5 rides on it... what really works best?
