Where to Ride Sunday
Frank
64
yes, it is SE OKC. If you need directions let me know. If we get any rain the riding should be good.
crashnburn
108
In tulsa here, would like to try OKC sometime just don't know about a road trip that far this weekend. If I can't find something closer I may take you up on it. What kind of trails, how many miles? How does it compare to Stillwater 500? Thanks.
Draper is fun. If it rains some it will be awsome, but then again, most riding will be awsome with some rain. Frank, it's good to see you on the boards again. The new 250 will likely get the suspension pulled this weekend so I'll still be on the 450F. Come ON RAIN!
mx547
Ortho doc's wet dream
4,787
103
xtremeworld in tulsa is having practice sunday, if you don't mind track riding. i'll probably be there.
crashnburn
108
Thanks mx but the track actually scares me alot worse than the trees. BSwift where you riding this weekend? 250 or somewhere else? By the way I went wed. out to the 250, there was somebody pulling out of the driveway of the trailer that is next to or on the land, I waved but he didn't look happy. Disgruntled neighbor, or just didn't recognize me?
We've got rain, slow and steady. The 250 should be pristine! As for the neighbor, not sure about that. His place is for sale so a dirtbiker might be able to get a good deal.:ride:
Frank
64
I havn't been to the 500. Right now there are about 30 miles of trails. As you go along it varies from grass track, tight trees, tight trees, small open areas, tigh trees. there is a small motocross track as well as a beginner trail. All in all fun riding. Here is a link http://riding.LakeDraper.com . They are in the process of expanding the riding area by a square mile and all the trails should be cut and marked later this spring.
Frank
64
Bswift, I'm guessing your in for a ride sometime down here. It would be good to see you again.
crashnburn
108
Frank, will take you up on Draper some other time, just got my suspension back and when I put it back together noticed I had bad linkage bearings :bang: I might go putt a little at the 250 but wouldn't want to get to far from the truck, till I get everything squared away. :ahhh:
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
