Sprintguy
24
I received the EE handguards/deflectors. I am less than impressed with the way they fit my handle bars. It looks like I will have to grind 1/8" to 3/16" off the ends for the bar to be able to attach to the inner mount. I don't understand why they don't predrill for their own hand deflectors.
Did the rest of you have to grind your bars for them to fit?
Am I over looking something? It appears the inner mount will go right underneath the cross bar. If I go over the cross bar then it pushed the outend out too far.
I emailed EE and they haven't replied.
What is the easiest way to remove the stock grips which look like they were glued in place at the factory?
Smit-Dog
4,704
I did not have to grind my EE bars down (purchased 1.5 years ago). They fit fine with standard Renthal CR-Hi bend bars, and even when I cut the handlebars down to 30.5" (although it was a tighter fit). I can't remember whether the inner mount attaches outside or inside the cross-bar.
I agree, it would be nice if brush deflector holes were pre-drilled. The rational though is that some guys don't want to run brush deflectors, and this also allows you to use non-EE brush deflectors. I went a few thousands smaller on the drill bit for an extra snug fit.
Call EE directly; I'm sure they will be able to help you out.
Cut the stock grips off, and remove all remnants of grip rubber and glue. Might be a good time to upgrade to a metal throttle tube. When putting new grips on, skip the grip glue, and safety wire them on. Do a search for more details.
Then go bust some bark!
MitchPeters
26
Freddette XCR2's. They are about twice as big as the Freddette handsavers and have more room than any other handguard made. They are aroud $100 though. I can email pictures of them if you want. They mount to the top triple clamp and have abushing to syill allow Pro-Tapers to flex.
Sprintguy
24
Thanks for the reply smit-dog.
I can grind the end of the handle bars to make them fit. It's not impossible work by any means it's just a little more work than I thought they would be.
Darn...I was afraid I was going to have to scrap the existing grips..oh well.
Sprintguy
70 marlin
2,963
With Fredette’s or EE's there always seem to be a bit of bending involved for the perfect fit. Even though my new one's (EE's) went right on the new Berg.
x2fast
Smit-dog....anytime there is a Moose question I will be more than happy to try and answer it.
Also if there are any concerns or dislikes with a Moose product please let me know.
I will help out any way I can.
ktmracer
378
Originally posted by x2fast
Moose has a totally new hand guard protector....it is pretty trick, easy to mount to the handguard, and offers a new design to allow brush and limbs to roll off the ends.
Check them out! On the Mooseracing.com site under products/controls/competition handguard protectors
http://www.mooseracing.com/HTML_catalog.asp?page_id=54&page_logic=Gear&page_title=Products
That design is the same one that the motonation wacker has been using for about a year.
Smit-Dog
4,704
And personally, I like my brush guards to extend more above and below the bar. Better to deflect branches from wacking the hands!
x2fast
It is TOTALLY different than the wacker....using a different way to mount, fully encompassing the aluminum handguard all the way to the bar end mount, thus making it one of the strongest and durable available. The end is built with a recessed mount to offer extra protection to the end mount. It is also very easy to mount using just one bolt. And it is available in 8 colors.
