RECENT POSTS
white residue on inside of oil level guage glass
anybody ever get this? white residue on inside of oil level gauge glass. it wasnt there before todays ride. after about 2hrs i noticed something white on the inside of the glass. it didnt move with the oil as i rocked the bike back and forth? could barely see the oil level but could see it. i run it at the top of the glass and i havent changed oil brands or anything. drained the oil when i got home and there was no water in it. the oil looked fine. thanks
Y2Z
Subscriber
my 89 does that too, i think its just moisture, it goes away when the bike sits for a bit
its not in the oil cz its a white residue on the inside of the glass itself. oil looked good.
i think im going to change the oil seal on the water pump shaft just to be safe. is there anything else i should check or replace besides this?
speedyts49
Subscriber
I had a simular problem, drained and checked the oil and saw no coolant. I repeated this and still I could not see anything in the oil. I changed the seals and the problem went away. I always thought that oil floated on water and you would see the difference but it seems they do mix too some degree.
The seal replacement is a pretty easy one and should fix your milky glass.
tom
thanks tom. you mentioned seals, i only saw one that looked like it would need to be changed on buykawasaki.com parts diagram. which seals did you change?
speedyts49
Subscriber
I recall replacing a couple of items. I'd ask the parts guy to be sure. I have also heard of the shaft being damaged (scored) and I think you can use some emery cloth on it if it is not too bad. Mine was just a bad seal. Do a search for more info on this.
good luck,
tom
