It is a 97 100cc two stroke.
She is 5'6" and 130lbs.
The bike is incapable of a wheelie unless she dumps the clutch.
Should a 100 two stroke not be able to wheelie with a 130lb rider?
Plug looks good (brown) and it starts EASY, usually on the firt kick. Has never fouled a plug in the two months we have owned it. I just did a compression test and got 120psi (which seems excellent considering the compression ratio is listed at 6.7:1) I also took the carb apart to have a look in there and all appeared fine. I cleaned the carb and reassembled with no change.
So, should an RT100 not have any power at all, or what?
If it should have power - any ideas of what I should look at cleaning/adjusting/fixing on it next?
Thanks,
Phil
Thanks,
Phil
