jbu0070
6
i ride a 2003 kdx 200 and at the end of last season my throttle began to stick at the worst times, when i say stick i mean the actual throttle handle returns to its neutral position but the bike continues to run wide open untill i shut it off, any ideas, thanks
MadArrow
89
If you let go of the throttle from wide open can you hear the carb slide clunk shut? If so you are probably looking at a vacuum leak somewhere.
bake
156
Some good leads there, I had a leaky base gasket do this to me as well as a frayed throttle cable. Better check it out before it hurts!
bake
fender92883
645
One of my first times on a bike, while going through some trail, the throttle cable pulled right out of the carb and it stuck open! :ohmy: I bailed in a hurry!
MadArrow
89
Same thing happened to a friend of mine (stuck wide open), but he didn't have a kill switch. So in a panic he yanked the plug wire! Kill switch was next on the shopping list. LOL
jbu0070
6
thanks for all the advice guys, unfortunatly it already put me on the operating table, lol, but i will take the advice. much appreciated
