Mrobbins
172
Also IMS. Very happy with the IMS Pro. They are wide and super sharp (when new). A search of this forum should turn up lots of info.
David Weber
6
do they fit?
My Austarlian delivery 91 model is an F3 (SR in the US) with the steel tank.
Do you know if the footpeg mounts are the same?
Oct 10, 2004
163
If you want to save some cash grab some 2 inch flat bar. Measure your pegs around the outside and cut the bar to length. Then drill a series of holes the entire length of the bar straight up the middle then cut it in half lengthways and weld the 2 pieces to your existing footpegs to make them wider just angle them out slightly as you are welding them
matt-itude
293
He is saying you figure how long of a peice of metal you need and then he is getting a peice of steel twice as wide as it needs to be. drilling a set of holes down the center then (the red line) you cut the holes right down the center that gives your extensions the teeth. then you bend them around to shape and weld on.
Green Hornet
837
Steel tank :ohmy: Is the sun down under that F#%KING HOT!
