Hey man
I've just bought a 1989 cr250 for a bit of fun at the weekends.
It hasn't been particularly well looked after and the gear lever was originally welded on.
I removed the weld and lever and noticed the gear shaft splines are not too great looking.
Does anyone have any simple or ingenious ideas for a permanent fix for this.
I've read all the threads concerning worn levers and I have a steel lever on my 1985 kx500, but the worn shaft splines would rule out the steel lever fix.
I'm well prepared to grind, drill or reshape the shaft before resorting to a full engine stripdown to replace the shaft.
Woodroffe key? Pin through lever and shaft?
Cheers man
Craig
Cheers man
Craig
