Picked up a used 2001 KX250 and I'm putting in a new top-end. Pulled apart the Power Valve this evening and WHOA :ohmy: . . . serious carbon build up and black goo !! I think I could scrape some diamonds off the stuff is caked on that hard. I'm on my second application of oven cleaner and it's just not cutting through the carbon build up. I don't think the previous owner ever disassembled the Power Valve. I have access to a glass-beader and I'm wondering if this would be too harsh to try and remove the carbon build up? It seems there is a "finish" on the components (similar to bearings) that is shiny and I would guess aids in smoother movement. I'm concerned glass beading the components may remove the finish and won't mesh/slide as smooth as it should. Do I have reason to be concerned, or could I just have at it with the glass-beader?
