Is there a problem with flipping the front sprocket to allow more clearance for an x-ring chain? The teeth are offset to one side more than the other so the chain doesn't hit the case. This is on a cr 250.
yes front sprockets u can flip round like the back 1, u will need to get a new 1 around 10-20 pounds, smaller faster off the start and bigger top end. good luck
