Best guess-I would try a compression test and note reading.Then squirt motor oil in sperk plug hole and take another compression test.If compression jumps think rings.Other Xrs have a rep for leaking valve guides.You'll note a lot of smoke on initial startup after bike sits,oil leaks thru guide into cylinder.Make sure there's no leaks at drain bolt for oil
