Anyone have experiance installing a high volume oil pump on these 50's? I have a pic but its in japanese. I heard you have to drill something w/ a 2mm drill bit. Is this true and if so what. Thanks for any info.
I bought the takegawa pump ... came with high flow pump gasket and drill bit.... if i remember right twobrothers web site has detailed info...but it wasn't that hard take it off drill the hole [ you can't miss it ] clean up all the shavings and gunk put on new one...you'll have to have the cylinder and clutch off to do this!!!!!
