Birken Vogt
- Apr 5, 2002
- 102
- 0
I bought a '92 XR600 with some aftermarket coil on it, and the lights weren't working. Well considering that there are 5 wires coming out of the mag cover (most not connected), and the schematic only shows 2 or 3, I had to pull the cover off to find out what was up. There I found a broken ring terminal on the wires that ground the ignition coil and 2 of the lighting windings (the thing has 3 and one of them has both ends brought out of the case). Anyway I fixed that and now I am waiting on a gasket to put it all back together.
In the meantime I was wondering if I ought to think about connecting one of the other windings, or if I even could. I was looking at http://www.all-offroad.com/DirtBikes/TrailTips/XRStatorRewind.html and saw that apparently the bike has stock 4 poles wound, and this aftermarket thing has 5. There are 17 altogether, 15 for lighting and 2 for ignition. So this guy that did the rewind is using 10 as opposed to the stock 4. I am guessing this aftermarket thing goes to other bikes as well where the extra windings are connected. Maybe an XR650L?
Well I am just rambling here. Having not ridden the thing at night I won't really know and any connections I may make in the future will be to the external wires. I don't want to get into rewinding the stator manually. Not that I couldn't, just too much effort.
For the record, here are the windings and colors:
1. 2 poles. One end black/red, the other grounded. Ignition (you knew that)
2. 5 poles. One end white, the other end grounded. Goes to lighting now, where stock would have gone
3. 5 poles. One end white, the other end grounded. No connection
4. 5 poles. One end pink, the other end yellow. No connection either end
Birken
'92 XR600
'88 CR500
Birken
'92 XR600
'88 CR500
