Yamaha Big Wheel, what type of chain does it use?
yamaha1
26
I am looking to replace the chains on my Yamaha Big Wheel. It uses a normal 520 chain in the rear, but the front chain is a wider chain. Yamaha wants $120 for it, even though it is only like 30 links long. Anyone know what type of chain it is? Is there a way to measure it and find out what size of chain it is? Hoping to find another sourse to buy it from. Thanks.
IndyMX
Crash Test Dummy
5,548
Amo, IN
is this one of those 4 wheeled vehicles? If so, don't count on much useful advise on here. This is a 2 wheeled forum. I think there are forums for the 4 wheeled vehicles, but I've never actually seen one.
junkjeeps
671
Whoa there Indy! Cut the guy some slack. He is speaking of a 2 wheeled vehicle. I have an '85 model BW200 myself. Quite a conversation piece as you don't see many around. If I'm not mistaken, they were only produced as a 200 in '85 & '86. The BW80 spans many more years than that. Is yours an 80 or a 200?
I'm not sure what size the chain is either. I looked at an online fiche and they don't give a size, only a part number and a price of $105. Have you tried taking the chain off and going somewhere like Motion Industries? Maybe a local bearing house would have what you're looking for. I bet Yamaha's not the only company/manufacturer to ever use that size chain. I'll see if I can get a better look at mine and come up with a better answer.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Thats why I included the "If so.... "... I don't recall ever seeing one, or ever hearing of one.
No hating going on, if there was, I'd have said something way different.
yamaha1
26
My Big Wheel is a 200. They actually made the 200 from 85-88. They also made a 350cc in '87 and '88. I learned to ride on a BW80. It was my first bike. They made these from 87-88 and again in '90. There is still a pretty high demand for Big Wheels and Honda Fat Cats, which are similar to Big Wheels. My brother has a Fat Cat. They both routinely sell for more now then they cost new. They make excellent irrigating and mountain bikes. I have a buddy that chains his up and uses it all winter in the snow, hunting and horn hunting. They go places that no other bike, short of a Rokon, will go.
Jaybird
Apprentice Goon
6,452
Charlestown, IN
The pins on a 520 chain will be 5/8" center-to-center.
If the chain you have has this pin center, yet is wider than the other chain, then it is probably a 525 or a 530 chain (both still a 50 series with 5/8" pin centers).
If the pins are 3/4" centers, you have a 60 series chain, probably a 630.
Measure the pin centers and how wide the rollers are, and we can tell you what chain to shop for.
yamaha1
26
Thanks for the info Jaybird. I got the chain off and it is stamped D.I.D. 50HDL. I did a search on this and came up empty. At least I now know it is a 50 series. I measured the pin centers to confirm and they do measure 5/8". The rollers measure from .375-.380" wide. The sprocket measures .340" wide. So is this a 525 or 530 chain?
junkjeeps
671
Jaybird,
I took a few measurements myself. I came up with 5/8" center to center on the pins. I didn't know what other measurements to reference, so I measured the width of the inner lengths at .58 and the width of the outer lengths at .80. These measurements are approximate with a cheap digital dial caliper. I'm just rereading your post and see you said to measure roller width. I'll have to check that one tomorrow.
Mark
yamaha1
26
I found a webpage that lists chain dimensions. Looks like it is a 530 chain. It lists roller width for a 525 at 5/16" (.3125") and roller width for a 530 at 3/8" (.375"). They also list sprocket width for a 530 at .343." Thanks guys.
