*william*
344
We just got a new '01 YZ125. I've ridden it and it's great. But I've been pouring through the manual and can't find "stock" susp. clicker settings. Also, does the shock have both high and low speed compression adjustment? If so how do I adjust this? The susp. works really well as it is (better than my KTM), but of course I want to fool with it...
Thanks!
robmann
70
Yes it does have high and low comp. on the top of the shock is your comp adjuster the regular screw driver slot is the low speed and the 17mm hex nut is you high speed, you have 20 low speed clicks and 2.5 to 3 turns on the high speed, start in the middle and work from there.
Porkchop
341
Check chapter 3 of your manual again (Inspection and Adjustment). The stock clicker settings will be in there.
