khwilm
5
I started to remove my engine today and when I went to remove my swing arm I discovered that the connecting bolt at the front of the swing arm was frozen. This is the bolt that goes through the swing arm and rear of the engine. I removed the nut on the gear shift side and tried to pound the bolt out with a hammer and punch....didn't budge. I then removed the engine bolts and tried to move the engine back and forth hoping to break the bolt loose...nothing. Any other suggestions? Thanks,
Kevin
97 YZ 125
03 KX 85
76 TR6
QKENUF4U
236
lay bike over and hit it with PB BLASTER for a couple days then BIG BREAKER bar on one side and hammer/punch on the other.
good luck
khwilm
5
I laid the bike on it's side last nite and soaked all of the joints with Liquid Wrench. A few good slugs with a hammer and punch finally got.
Thanks for your help,
Kevin
97 YZ 125
03 KX 85
76 TR6
