Hi there I put in a new clutch basket in my 82yz 250 last night and noticed that the water pump drive sprocket was loose on the crank shaft. It looks to me that that is the way it works but i'm not sure. I can press the sprocket on to the shaft and it will stay there but I think it may slide off or turn on the shaft making the water pump stop spinning. I looked pretty close and only see a bolt, locknut but no woodruff key or pin to hold this sprocket from turning.
Hopefully I explained this right and someone can help.
I also looked on the Yamaha parts cateloge online at the sprochet assembly and it looks to be all one peice. Could it have been welded and broke?
Thanks Andy
Thanks Andy
