YZ250 Vibration
lwsmithjr
Subscriber
First, if this has been covered in the past, I apologize. I did a search and only came up with handlebar info.
I have a '99 YZ250 that I have owned now for about 4 months. This past week, my 15 year old (who races a YZ125 and YZ250F) rode it for the first time. After 1 lap he brought it back and said "How do you ride this thing? The vibration is awful."
It's been awhile since I've riden a 250 two stroke so I don't know if mine is "normal" or not. I do know that my hands start tingling after about two laps, and after 4 they feel like they are asleep, but I thought it was just because I'm old.
What is excessive? Is what I'm experiencing normal? Is there things I can check or do I not worry about it and fill my bars up with silicone? (they are 1 1/8' Pro Tapers BTW.)
Thanks for the input.
jmics19067
Lifetime Sponsor
things too check since it was a used bike. all bolts especially motor mount bolts should be tight. take off the ignition cover and see if you can wiggle the flywheel up and down, if you can you need main bearings. Piston clearance being excessive and all of your exhaust hangers,springs and rubber grommets.
I would say that if your hands get numb from vibration not from arm pump something is amiss with the bike not you.
Studboy
Thinks he can ride
Most modern 250's are fairly smooth. I would check the engine mounts and then check the main crankshaft bearings......it shouldn't make your hands go numb.
lwsmithjr
Subscriber
Checked the engine mounts -- good and snug. The pipe however was very loose. What I don't know at this point is if that was the cause of the vibration, or the result of it. Flywheel is tight. Main bearings and/or piston slop could be the problem.
Thanks!
marcusgunby
Lifetime Sponsor
Make sure the pipe o rings or what ever seal it uses are in good condition-also the pipe springs-these slacken over time.
bclapham
Lifetime Sponsor
250s make lots of noise and viibes, getting on a 125 after riding my 250 i cant even tell if its running or not. just check everything and put a new piston in at some point since they dont last forever.
darringer
Lifetime Sponsor
If you want to feel vibration, come ride my 99 CR250. Now that's a vibrator! I've done all of the tricks and I can still feel it through the bars more than other bikes I have ridden. I have gotten used to it, and had to alter my riding style a bit. I try not to use a "death grip" on the bars and relax more.
lwsmithjr
Subscriber
I got to ride at Monster Mountain this past weekend. The loose pipe was not the cause of the vibration -- it's still there. The guy I bought it from had supposedly put in a new topend just a few months prior but I'm guessing it was probably longer ago.
I had fun anyway -- just can't stand more than 4 laps at a time. I'm gonna pull it apart.
Rcannon
Subscriber
I noiticed much less vibration on my YZ 250 after installing aluminum bars. I used pro tapers in the Henry bend (thanks Studboy!!!!!!
I still cannot help but think that a piston bad enough to cause all this vibration would have broken up by now.
I know how you guys all love apple and orange comparisons so here goes.
I just replaced my YZ 250 piston that had been in my bike for 2 1/2 years. I know I have at least 60 hours on the piston...maybe more. The vibration level is identical to the old piston. The power might be slightly better, but if I changed the piston to lower vibration I would have been mad!
Best of luck and let us know if you find anything out.
darringer
Lifetime Sponsor
I agree with the Rcannon. Aluminum bars will help with vibration. Also, I filled the bars with silicone caulking and it cut the vibration even further. I've had a bike with so much piston slap I was amazed the skirt didn't break, and it did not vibrate any more than when I rebuilt the engine.
yeh my 99 cr 250 has some serious headshake too but i got used to it after millions of hours of riding i have twin walls with super soft grips and it helps but its nice to get used to that bike cuz i have never got arm pump on any other bike i ride some races here in the worst wooped out track that are sand and when i first got the bike i could only do 1 lap and now i can do at least 5 or 6 at my fastest pace just keep riding and go thourgh the pump it makes your arms stronger and remember BREATHE!!
lwsmithjr
Subscriber
I've got Pro Taper's on the bike now with some really soft Tag grips. I have not tried the silicone fill yet, but I will do that before I tear the motor down.
Incidently, the bike came w/ an 11 oz. Steahly flywheel weight (not installed now or when I bought the bike). Is there any possible way that the additional weight, when it was on the bike, could have gotten something out of balance? I realize it shouldn't, but could it?
BTW, kdxmadman, when you're over 40 you have to breathe. Holding your breath for more than 30 seconds is life threatning!
I've heard that flywheel weights put more strain on the crank bearings. (I personally have a 12oz aloop flywheel weight thats been welded on since 1998 and have yet to have a problem...knock on wood, though i do find it vibrates a bit... Might be time to take a look at that too. thats what winter is for! :) )
Eric
darringer
Lifetime Sponsor
I have a 12oz. flywheel weight on my CR and have not noticed any additional vibration from it. I have made back-to-back runs with and without the weight and there is no change, other than mellowing the powerband. Oh, by the way, when you're over 40 almost everything done on a dirt bike can be life threatening!
Studboy
Thinks he can ride
Weird.... I've never really thought that my 250's vibrated much. My 02 YZ250 feels silky smooth to me, my KX vibed a little bit but NOTHING CLOSE to making my hands go numb. My dad's Mod. LT500 vibes a lot, but that is expected...
I would still check your crank out.
