There should be a little screw on the reservoir( a little canister looking thing), turn that as if you were tightning it and that should stiffen it up some. Theres also a little screw like that on the bottom of the shock.
The stock springs should be OK for you , they are .29 up front and a 4.8 out back ( assuming they have not been swaped out )
Set the rear sag at 80 mm's .
