Jun 14, 2007
22
It is a 01 yzf426.
So far i have tried pulling it off with a ATV in 3rd gear, kicking it a million times and rolling it down the hill.
I checked the spark plugs, it doesnt show a spark but when you hold it it will shock you.
Any tips would be greatly appreciated.
Start with the basics.
- Verify the carb pilot jet is clean and the air bleeds in the carb aren't plugged up.
- Check the valve clearances.
- Check the coil wire, spark plug cap, and coil ground.
- Put in FRESH gas and a NEW plug.
Jun 14, 2007
22
I am just getting back into dirt bikes. The last bike i owned was a 88 honda, needless to say i dont really know all about what you are saying rich.
The only thing i have done so far is put in frsh gas.
I believe i will take it to the shop and let them work on it and also pick up a owners manual.
Thanks for the help.
*EDIT- I did a search and read a thread were a guy was planning on buying one, another fellow posted that there was a certain sequence to start the bike, and he diddnt list that sequence, so if anyone knows it will you enlighten me please.
bsmith
Wise master of the mistic
1,782
That sequence is on here, try searching for YZF 400's as well. The had the same sequence.
1 Pray
2 face bike north
3 Pray
4 Kick
5 if you held on to the throttle and cracked it open a millimeter, park and try again tomorrow
6 Take asprin for the pain in your leg
7 :laugh:
