Y2KWR400FM
- Oct 15, 2001
- 5
- 0
I have installed a ZipTy Link on my 2000 WR400 and have had a lot of trouble getting the rear suspension set up correctly. Sag is set at 100mm(need a stiffer spring to lower my sag). The rear doesn't seem to hook up and violently kicks out under hard throttle conditions. This bike is a handful to ride already without the traction problems:scream: ! I was told by Ty Davis' wrench to really soften the rear rebound(17-18 clicks out?) and to soften low speed comp. 3 clicks out from stock and high speed comp. 1/4 turn softer, but these adjustments haven't helped. I have tried going stiffer on those 3 adjustments and it seemed to help but not enough to get nice flat traction. I am currently on 10 clicks rebound, 8 clicks out on low comp. and 1 turn out on high comp.. Had any experience tuning with this Link? Any suggestions would be greatly appreciated.
