well i put my new pads in and bled the brakes but now they feel spongy. the lever doesn't ever feel hard. the brakes work fine it's just the feel. any suggestions?
keep bleeding, another old indian trick is to let the bike sit over night. Take the cap off the master cylinder and get a screw driver pry easy between the rotor and the metal part of the pad. Not on the friction part and force the piston into the caliper and it should push the air out.Good luck. Or you can take the caliper off a push the piston in. I am just lazy.
