I did a search on this but couldn’t find anyone with the same issue.
I have a 97 CR-250, some and me buddies were out riding this Saturday. I went to launch the bike getting a run a at a small hill climb. As soon as I started to take off I felt something in the clutch kind of slip....I pulled in the clutch to stop but then the bike died like I had dropped the clutch when I actually had it all the way in (there was no tension on the clutch). My first reaction was that the clutch cable had broken.....no big deal. Well once I got it home I removed the ignition cover to examine the other end of the cable. And it was still intact. I could feel the play when I moved the actual arm that goes into the case.
Here is the real kicker. My buddy while I was looking at it was able to adjust the play out of the clutch with the adjustment up on the bars! Once this was done the clutch felt fine. I started it up and tested that it engages and disengages the clutch properly and it does. I still have not ridden the bike since then because I’m still not sure what really happened. Any of you guru's out there have any ideas?
:scream:
:scream:
