I'm in the process of restoring a 1987 CR250, and before the final teardown, I need to make sure everything is working like it should. The bike starts and runs fine, but it instantly dies when you let off the throttle. I know that this bike runs the PK Kehein carb, which incorporates the idle control and choke. When the choke is on, the bike will idle and run fine.
I believe the pilot circuit is plugged which is why it dies so quickly when you let off the throttle. Is this correct? All that is needed to keep it running is to have the throttle cracked. Thanks for any help.
