Clean your plastic thoroughly and dry before starting. Keep the stickers on the backing paper, pull one small edge back on one side. Use the backing paper to allign the sticker keeping it centered and straight. Pull the paper off and role the sticker onto the plastic from one end to the other. Role out air bubbles as you go. Go slow, and take your time. Do not push down the sticker to the plastic too quickly or until you have the wrinkles and air bubbles out. The sticker should fit perfectly onto your plastic, so make sure you have it straight when you start. Accetone is a great adhesive remover, but make sure you get it all off the plastic before you put on your new stickers. Rob Ellingtonbeamer101 said:I bought a set of amsoil graphics. does anybody have a tip as to how to best put them on?
