HELP NEEDED - CR250R Engine Installation
rikhek
67
Need some help please. Removed the engine from my 2000 Honda CR250 last night. I already had the cylinder head and cylinder removed from the engine.
I'm wanting to put it completely back together prior to putting it back. Will I be able to fit it back in assembled. Sure seems tight....
TIA.
Rick
IndyMX
Crash Test Dummy
5,548
Amo, IN
I have been able to remove and install my complete 450 engine. It can be done, but if you're doing it in a shop, why bother? Set in the bottom end of the engine, and then reassemble the top end.
Much easier that way.
dirt bike dave
5,349
After a bottom and top end rebuild, I put my old '99 CR engine back in with the cylinder on. I guess the frame is slightly different than the '00, but I don't remember any trouble.
