I am trying to get the 310 jetted correctly and have ran into a few problems. Since I don't have convenient access to a riding area to just learn by trial and error, I was hoping a some of you could give me a little more insight so I can kind of get a good Idea before I go riding again. Here is what is happening:
1. Bike will not idle on its own. I have to crack the throttle when starting it, hot or cold. It used to start with the throttle totally closed on the first or second kick. To get it to idle I have to blip the throttle every couple of seconds to keep it running. Also, while doing this it will immediately die when I wick open the throttle if the revs are really low. Does this sound like a too rich condition or too lean? Even if I manipulate the air screw until it sounds crisp, it still will not idle or start without using the throttle.
2. When under a light load, at about 1/4 to 3/8 throttle the bike will make a loud crakling sound, and not really run smooth. This is a sign of being too rich on the needle, right? But when I'm cruising along in 4th gear and roll on the throttle, it makes a telltale boooowaaaa sound (lean). Another thing, when I was riding in the sand this weekend, mostly 1/4 to 3/4 throttle, the bike got hot and started spitting coolant out of the overflow. I don't get it, the crakling sound tells me it's rich, but the booowaaaa sound and the overheating tell me its lean....
3. I think the main jet is ok, although I have not been able to do a plug chop since I lack an area where I can go wide open in 5th for 15-20 seconds. It sounds good and pulls hard when wide open. I think the main jet may be a little rich, but I don't mind. I would rather have it on the rich side then too lean.
I think I have the main about right, but am having trouble with the needle and the pilot jet. Also, after riding all day, the plug was black and wet. When an engine is bored and ported, is it common jet leaner or richer to compensate? My guess would be richer due to the engine pulling in more air, but obviously I don't really know. I realize trying to jet an engine over a bbs is impossible, but maybe some one can give me some pointers. :)
For you guys that are running kx310's (preferably 2000 models) how much did you have to alter your jetting from stock. Oh yeah, here are the details of the bike:
2000 kx250
310 big bore kit from eric, ported for mo' better everywhere
PC Platinum pipe
stock reeds, silencer, and air filter.
2000 kx250
PC Platinum pipe
