I just did a total rebuild of my 2000 KX 125 including low end portig by Mr. Gorr. After 3 heat/cool cycles I did a compression test. I got 145 psi at 1800 ft elevation (I live in New England in the mountains). Is 145 acceptable at this elevation? My manual says 125-190 psi is the range, but I assume that is at sea level. This was my first topend on my own and I want to make sure it is ok before I rally ride the old girl. I am trying to etablish a base line to keep track of engine condition. Thank you in advance.
