I have a 01 KX250 Fuel Tank that has a 6mm threaded insert that mounts the Radiator Shroud and it spins while removing the mounting bolt. The bolt head has been drilled and now I need to drill and re-tap the hole. Thinking about getting a left hand twist drill bit in hopes to remove the remains of the 6mm bolt while drilling. Any ideas? The insert was molded into the tank so I guess the plastic just didn't flow well around the insert. Sure wouldn't pay to replace the tank for something so minor...
Thanks for any ideas.
