The water pump on my 500 is driven off a gear that's attached to the end of the crankshaft (just like all 125's and 250's). It APPEARS that this gear is pressed into the end of the crank. (I'm going off of exploded drawings from Kawi's website). Now that this gear is screwed up on my bike and needs replacing, I'm at a loss on how to remove it. There is no way to get a gear puller on it......it's pressed down flush with the end of the crank. My only option seems to be to drill and tap it and try to pull it with a little 1/4" bolt.....or have a big 1/2" bolt welded to the gear and use it to pull it out.
Anyone out there have any experience replacing this gear?
